Lady wife out all day so had a full run on the build. By the way, I'm assuming this is of genuine interest to someone out there - the impetus being that i tend to trawl for images of builds etc before i get started, so the detailed pics are supposed to be of use to others planning a build. :tennis:
Anyway, here are the motors mounted and leads neatly platted…
Next job, which took a yonk, was making up 18 connection leads fro the motors - no pic needed, 18 wires with a bullet at each end.
The original hexa had everything done by the book - with everything hard wired to everything else. I'm determined that this build is going to be much more friendly when it comes to fettling, so trying to have everything as modular as possible - with easy access. Lots of work now for less work later.
Here is the buzzer and one of the rigger led strips - easily removed/disconnected with jst plugs.
View attachment 1299View attachment 1300
Next up the orange rigger cabling.
First pic shows the routing of the cable to the rigger LED strip - you can also see that i've wired the motor mount LED's up to the pads in the centre of the LED strip - to reduce cable run. Second pic shows the finished rigger from the other side, showing the buzzer mount and (now) protected motor wires.
View attachment 1301View attachment 1302
You can also see the new 5mm prop mounts and 8mm-5mm reducers on the motors.
I farted around with this for bloody hours, but it's finally coming together now. It was also a right fiddle to get the finished riggers into the frame without it all flopping around, but that's done.
Final job yesterday was to tidy up my FlightCtrl board. I removed the spektrum connection leads, bridged the jeti jumper and cabled it up for the new radio as I'm planning to swap to an MX-20. Would prefer the new Jeti, but it looks like that's not going to appear until next year now and i really don't want to trust this build to my spektrum radio - too many stories of "Mk's going 'odd' for a few seconds while in the air". I'm a big fan of the DX8 and more than confident in it for other models - when using the full receiver/satellite combo, but my flying skills don't need the added risk of radio hijinx.
Again, in the original build i was a bit worried about soldering and heat through components, so i used a cooler iron and a fine tip. This was a mistake.
I've subsequently found that a regular size tip, as much heat as my 48w station can throw at it (455º) and being deliberate with each action to be the way forward. This means almost instant, clean joints - touch-and-done.
