Help .. Having trouble getting IOSD Mini wired right
38super
Hi All
I tried last night to install IOSD Mini on my quad with no luck. The camera I'm using is the small Sony WDR770. The cable is the sn777-molex three pin cable instead of the RCA plugs that the camera comes with. Three wires out +- and signal. On the diagram that came with the mini they have four wires out ,Video signal to transmitter, GRD, Video input and GRD. I cut the cable and attach the appropriate wires it leaves me with the Pos wire out of camera which I attached to the transmitter. I applied power and picture came on but without the IOSD showing at all. Went to assistaint and did not show IOSD was on line system is V2 and IOSD is plugged into the PMU. Can anyone tell me step by step how to set this up with cable and camera I have
Thanks Will
38super
YAAAAA I got It going ......Looks good on monitor.....Another quick Question ? I do not plan on using power from my 14.8 v main power batt except to use a few cells to power gimbal running off balance plug .then use a 1000mah 11.7 batt to run video
. It's a small Zippy batt or would it be better to run every thing off main battery......How to you guys power all the other extras
I have done it both ways.. It really is just a matter of preference. I use a separate battery now to power the gimbal and vtx, that way I don't have the gimbal powered all the time. You could do the same with an inline switch or plug off the main power source.
