Help !!! Flight Time F450
Hi i have a stock DJI F450 with dji 9443 Props
GB200 Gimbal
SJ4000 camera
Boscam TX
800mah battery for TX and gimbal
Naza v2 (was a lite)
1st level Battery levels in Naza are set to 11.50 with 0.50 loss = 11v
2nd level Battery levels in Naza are set to 11.10 with 0.50 loss = 10.60v
with 3000mah 3s eflite 30c Battery
AUW is 1643g
with all this im getting around 3.30 before i get the low battery warning coming on and 30s later im starting to lose power.
with Turnigy 5000mah 3s battery
AUW is 1890g
with all this im getting around 7.30 before i get the low battery warning coming on and 60s later im starting to lose power.
I have ordered some graupner 10x5 props just waiting for the nuts to turn up to try them.
Without the camera, Gimbal, TX and extra battery i get around
3000mah 3s AUW 1250g = 7.35 till flash and 10.35 when i landed with 11.3v still in battery
5000mah 3s AUW 1405g = 9.53 till flash and 12.42 when i landed with 11.4v still in battery
So now im lost and want to tap into you guys to find out how i am going to extend my flight times.
I mainly want to use the F450 for AP stuff not that worried about flying it sporty.
I cant afford to buy a whole new set of motors at the moment so that's not an option.
So any suggestions would be really appreciated.
eskil23
Wikipedia Photographer
I would set the 2nd level almost one volt lower. First level is also a bit high.
Gary Seven
Rocketman
Jon, I agree with @eskil23 that your voltage settings are way too conservative. Here is a link to a post I made in another thread some time back:
http://multirotorforums.com/threads/naza-m-lite-first-flight-problems.22435/page-3#post-191782
With those settings I was getting a good 15 min flight time before the alarms went off. Off course, this is all dependent on the battery type you are using. For example, the voltage settings I have work well for my FlightMax batteries but are way off when I use Multistar. As of late, I have disabled the voltage alarm in Naza and use an on-board voltage sensor/alarm, set at 3.5V (also noted in that thread link).
HTH some.
Gary Seven
Rocketman
What about the props what would be my better option
Can't say as I have never used anything but the stock DJI props. Is your F450 setup with the DJI E300 system? If yes, then at least in theory the rig is "tuned" to work best with the stock props.
Maybe someone else will chime in here?
yes
Yes im using the stock E300's on my F450 just a bit worried if the weight is too much for the stock blades although must admit although short in time it does fly well with them.
have just tried my new Graupner 10x5 props must say they sound nice and it flies just as well as with the DJi9443 props will have a go again with them tomorrow and see if there are any time differences between the 2
Have also done as you suggested and reduced the 1st limit to
11.1v with a loss of 0.3v = 10.8
2nd Limit to
10.8v with loss 0.3v = 10.5v
are these now too low
ok guys this morning i tried flying my F450 this is my current setup
DJi F450 frame
DJi 920kv motors
Graupner 10x5 e-props
Naza m2
Orangerx r800x reciever
GB200 Gimbal
SJ4000 camera
Boscam VTX
Turnigy 800mah 2s (for TX , Gimbal & SJ4000 power)
Carbon Landing Frame http://www.ebay.co.uk/itm/3213507064...%3AMEBIDX%3AIT
So i was told to try manual mode to try and find where the hover point was on my controller (wow how hard is it to control i really couldn't imagine flying in this mode i like the auto leveling that atti and gps gives me) and with my F450 weighing in at 1890g with all the gimbal tx sj4000 and tx battery (43g 800mah) im finding the hover point at around 70-75%.
This is obviously too high from what i have read so is my only option to go up to a Hex like F550 or s680 pro as noticed the F550 has a takeoff rating of upto 2.4kg?
Or can i just upgrade the F450's motors???
If its not as simple as just upgrading the motors or props and does mean upgrading the frame as well could someone give me an idea of what motors to get that are not too expensive that will work well and give me decent flight time with around 2kg AUW.
eskil23
Yes, you can uppgrade your motors, if your ESCs can provide the current they need.
Sunnysky X2814 1100kv can give over 2 kg thrust with 10x5 props, but they'll pull over 40 amps at full power.
