hello from uruguay, I am new in the forum
jmendoza
I´ve destroid my qr 350 pro. so with the transmitter devo f12e , the receiver rx705 and the control flight devo m.
i would like to built a bigger drone.
the target is 50minutes of flight.
anybody know if the devo m can control 6 or 8 motors?
How I choose the motor , prop and batery to reach the desired flight time?
Welcome to the forum!
It looks as if the flight controller only has 4 outputs. So you may need to update to a newer FC.
I think your best bet for getting very long flight times is to do some research on low Kv motors with large props, and pump the numbers into ecalc to see what you can come up with.
50 minutes is a lofty goal.
Good luck and fly safe!
jmendoza
Which FC works with the devo f12e and the rx705, that also works with the mission planer? I couldn´t found the protocols form walkera of the redio and reciever
APM should work with any radio/receiver. You will only be limited by the number of available channels.
It appears that the receiver you have is a 7 channel - and you may find yourself wanting/needing more.
dazzab
I love the fact that people from all over the world join in here. Good to meet you. It will be interesting to see how you go with your goals.
