helloman1976
Ziptie Relocation Expert
Thx, Helloman,
I'm a little confused here. I intended soldering the battery wires to the correct spots on the power distribution plate. And then I thought that the BEC ought to be soldered to those same spots.
So do the ESC's get their power from the BEC or from the power distribution board. The ESC's power the motors don't they. Hmm. The motors don't connect to the power distribution plate.
So 8 gauge wires soldered to the power distribution plate and meant to be the direct battery cables is best? You've got me scratching my head again.
As for the charger, $110 didn't seem excessive for something with good features and which can accommodate future needs. And it doesn't need a separate power supply. It's not the Hyperion top of the line expensive one.
helloman your help is invaluable and now I wonder if our talks ought to be carried on in a different thread on a different sub forum. I think this thread might be distracting from the intent of the newcomer's introduction board. Even though I bet many newcomers introducing themselves have learned a tidbit from it.
There are lots of newcomers introducing themselves. The hello from the left coast thread has become too big for it imo.
Best, Rob
Ok let's go from the top because I know it's a lot of information and of course it's possible I'm not understanding you clearly. This is going to be like the "bone" song, the foot bones connected to the, leg bone, the leg bones connected to the knee bone lol....
Ok so the DJI F550 has a built in PCB board that you can run your battery power through to your ESCs. The main connector. where the battery will hook up, to the PCB board should be a larger gauge wire, I use 6 but you can use 8 if you want that should be fine just don't use 12 gauge here. I soldered my ESCs directly to my PCB board so I didn't need any wire and I'd use the same gauge as your ESCs but you don't have to as long as it will flow enough power without burning up, stranded 8 gauge will do that, so will 10 and maybe 12 too. I flow about 15A MAX through each ESC and only for a few seconds or I'm 1,000 feet in the air lol. From the ESCs the next set of wires is the 3 set that comes out and goes into your motors. The ESCs get their power from your battery and should connect directly underneath the arms, one ESC to one arm and one ESC to one motor etc. Hope that clears things up.
So, PCB board main connector can be 8 gauge and this is where you main battery will plug in. Under each arm there is a positive and negative tab, this is where your ESCs go and where they get their power from. The ESCs connect to the motors, if they end up spinning the wrong way then swap any 2 of those wires and the motor will reverse. PM me if you need anything else so we don't flood this thread
The charger is fine, it's not bad or anything like that but you could save some money by going a different route is all I was saying. Just trying to save you some money, this stuff gets REALLY expensive and I didn't want you out buying up "brand name" things because that's what you saw in a magazine or online ad or something like that. And, I was letting you know that the cheaper stuff works too and I personally NEVER use anything other than BALANCE and STORAGE mode and that's it and I've been doing this for 20 years now, R/C that is.
PS - I use a voltage regulator that's also soldered to my main PCB board that gives me a constant 12.6V no matter what type of battery I plug into my copter making it universal without any changes and giving my video transmitter maximum voltage. We can get into that part later though and I can show you pictures for clarity if you'd like.
