Heat shrink on step down regulator?
Quick question: think it's ok to put a bit of heat shrink on a step down converter? I assume that these things dissipate excess power as heat, but I figured I could open some holes on the top for air. I'd be more comfortable not leaving it wide open to the elements on top of the craft.
G
...guest...
Guest
I've got my Pololu 5v stepdown completely encased in heat shrink past the connectors and it seems to have worked just fine. You bring up a great point about heat dissipation though and will keep an eye out. The stepdown is used to power (not trickle charge) a Mobius action cam.
Thanks Ronin. I'm using it to power a gimbal which is more happy at solid 12v from wither a 4S flight battery or small dedicated 3S.
you can heat shrink it,, in fact you should. I implant them things into foam wings with gorrilla glue and they work for hours on end in the worst heat ever.... never failed
jes1111
Heatshrinking it will also help protect those soldered joints against vibration and bending - so make sure the heatshrink goes a little way up the wire, like on an ESC.
Thanks guys. The joints are the points that concern me most, so they'll definitely be covered. The exposed +/- are a short waiting to happen in some bizarre crash or mishap.
