FPV HDMI to AV Analog Signal Converter for most Camera
SEE POST #9 BELOW BEFORE YOU ORDER
Supports SONY/Panasonic/Canon products
Use the matters needing attention:
To the camera's HDMI resolution is set to automatic, part of the camera does not have the HDMI resolution automatic function, may not be able to support, to modify the camera resolution, must eliminate all connecting lines, and shut down and reboot, the new settings to take effect.Camera settings, system of PAL and NTSC and HDMI adapter cards, only the resolution.effects of output.
VIDEO output resolution: 720*576 PAL
The cable length for HDMI port to MINI is 150mm, its width is 9.5mm
weight only 19g
Include.
HDMI TO AV module *1
Super soft HDMI Mini HDMI cable adapter *1
AV signal transmission cable *1
http://www.hobbytoys77.com/aerial-fpv-hdmi-to-av-analog-signal-converter-for-most-camera_p2800.html
weight only 19g
Include.
