H3-3D Naza V2 smooth ramp-up tilt axis motion
Revoflite
Hi.
I'm using stand-alone GCU H3-3D along with custom build X8 multirotor running Naza V2.
Besides getting slow tilt axis movement(using "delay" option on my Jeti DS-14 transmitter) is there any way to get a smooth ramp-up at the begining and the end of motion(like on this video https://www.youtube.com/watch?v=7nJfODfHmx4)?
Even with 10 or more secons of delay setting the movement starts instantly at constant speed.
It seems only Phanton 2 has this feature available in assistant software, am i correct?
Thanks.
Darson Hall
Hey,
Yes you are correct. It seems you can only customize gimbal settings on the Phantom not the stand alone H3-3D. Very frustrating as many have spent hours trying to do it—since it can be done on the Phantom you assume it can be done on the stand-alone H3-3D, but no....
hexhome
Television Broadcast Engineer, SUSA operator
I have found that introducing servo delay causes the tilt to overrun, ie. it is difficult to stop at the exact framing required. I have resorted to removing all delay and placing a piece of fuel tubing over my tilt lever to introduce 'smooth' resistance into the operation. Apart from some miniscule 'spring back' it works reasonably well. That said, I too would like to see a better solution designed in!
