Just make sure your weights are correct with all the components - and that it equals that 1400 grams.
Ultimately you want to have throttle at 50% - try slapping 4S battery in there and see how it effects it.
Hmm. Yes. The throttle went from 60% to around 30%. Thought something else failed as "max. power over the limit of the motor. Please check the max. power limits defined by the manufacturer". The "Electric power" got over the limit. I tried with another motors (SunnySky 980kv) and the same thing happened.Just make sure your weights are correct with all the components - and that it equals that 1400 grams.
I am not sure that I have the weight right. I put 1436g into the model weight. In this I included the battery, ESCs, motors, flight controller, frame, props, tx module and power distribution borard. Should I skip the battery even if I have chosen "incl. drive" in it?If you swap to the sunnysky 700kv with 4S you'll get 49% throttle with about 15min estimated hover time. You just have to try out different parts that are available to you until something makes the most sense.
Check out other builds - that will take a lot of the guess work out of All this.
Ok. Thanks. If I have without drive, what can I exclude?![]()
