gb190 racekit build
danq0
My last thread looked too much like spam and was deleted :(
anyways I edited it accordingly, hopefully this one will pass
COPY AND PASTE: gearbest.com/multi-rotor-parts/pp_413709.html?lkid=10005809
Build of the GB190 Ultimate Race Kit
The last kit gearbest came out with, already had some SERIOUS power, this kit is serious OVERKILL!!
Emax RS2205, 2300kv motors, LittleBee 30AMP ESC's, all on a tiny 190mm XFrame...I'm scared to fly this :eek:
Included Contents
-GEP-ZX5 Carbon Fiber 190mm XFrame
-SPFRacing F3 10DOF Flight Controller
-EMAX RS2205 2300kv Motors
-LittleBee 30Amp 2S-6S ESC
-1000TVL Mini Camera
-5.8ghz 500mW VTX
-5.8ghz Circularly Polarized Antenna
-5045BN Triblade Propellers
-Power Distribution Board
-Misc. Hardware
BUILD IN PROGRESS...
Detailed specifications:
Videos
Unbox
Build Progress...
Frame
Arms are bolted to the frame
the screws are held on by an aluminum bracket
test fitting middle piece
test fitting top plate, this will hold the camera, VTX, and an action cam if you choose to
Frame is done
another shot of fully assembled frame
Installing PDB, I purchased my own PDB> this one comes with LC filter, BEC's, and OSD.
danq0
more progress...
IMO these ESC's are a little too big for this frame, it fits, but barely
Started removing ESC wires on the motor side
motor wires need to be cut down to size to fit
95%of motor wires was cut off and soldered to esc
ESC signal and ground are soldered to flight controller
soldered on XT60 connector
assembled camera and camera adapter
installed VTX
Put everything together and here is the final product:
