OK taranis gurus. This one has me stumped. Hoping for a logical solution. I've tried a few to no avail. I imagine any radio setup would work in the same logic.
I have a taranis/naza/gains situation. I have a 650 with three different size/weight batteries. Each battery requires a different gains setting. I know to lock in the gains using a three level switch and curves and it dials them in relatively close, but is there a way to use a dial to fine tune the initial switch settings (+/-) while in flight?
Also, one of the gains is not linearally equal to the others (I used X1 and X2 to figure numbers and record values). Is there a solution to adjusting that figure independently using gains on the same channel? For example:
Channel 5: gains (x1)
Initial switch SC up: 170/170/135/170
SC middle: 204/204/159/204
SC down: 227/227/50/227 (heavier 10k mah)
That last "50" is way off from the others.
Is this even possible? Any suggestions or pointers greatly appreciated!
