Need Help! fpv power filter
hello,
i've made my own fpv power filter using an online tutorial and it worked the first time i tried it,
but after i made a few changes that didn't work i returned to the previous setup (that worked)
but it stopped working and the noise was back as if i didn't add a power filter, i tried connecting the camera to 12v directly and then connected the power filter and it didn't make any difference.
i'm sure all the wiring is correct and the camera works okay, the noise is evident only when i use throttle
what could be causing the problem?
thank you in advance
hi, thank you for replying
so at the moment after a few changes it looked like it was giving a good image, the connection wasnt the same as in the tutorial (we connected it the wrong way at first and we have no idea how but it worked), after connecting it how its supposed to it stopped working, so we went with the previous (no correct) way and tried flying it this morning,
when touching the transmitter we got noise and it was difficult to fly fpv
we noticed that one of the motors started later than the other we are now trying to find out why since we calibrated the ESC
after a few check we noticed the antenna connection to the transmitter was a bit bent and the solder might have been compromised , we sorted that out and trying the fpv while in hand seems to work (didn't fly it yet)
we hope this was the main problem and was sorted out
all the images are attached, if you have any idea why we are having this error we would be most glad
the tutorial video (note we ordered power filters and are waiting for thier arrival)
antenna connection
our connection
