FPV & Naza M Lite
ZANE
Morning every one,
Just a quick question (that has no doubt been asked already)
I have just built my first quadcopter using the Naza M Lite and was wondering if any one could advise on a good but affordable FPV system that will work with the Naza M Lite.
Budget wise I'd be looking for something reasonable maybe about £200 ish.
Just need something simple, just so I can expand my knowledge.
Cheers
Zane
The fact that you have a NAZA M lite is irrelevant. The FPV system is totally separate. Get an all in one package deal like cootertwo suggested. They have some that are powered from the balance plug of your lipo otherwise you will have to solder in a connector. The system should work with a range of voltages or at least 12v assuming your using a 3S battery. Its helpful if you just power up the transmitter and then it powers the camera (one less thing to worry about) A 200 mw transmitter is as low as you should go but there's no need to get one bigger than say 600mw. Go with 5.8 ghz. A nice upgrade is the cloverleaf antenna too. Dont forget you need a receiver and a monitor or goggles. I like the fat shark stuff because its pretty much plug and play but its a little more costly.
ZANE
Hi Guys,
Thanx for your valued advice. Spot on :)
Time to go trawl the hobby king website for some goodies :)
