Hi everyone, I am currently Building a Next Level 650 with the DJ NAZA M V2 w/gps. It's actually built but I am just waiting for a new Futaba receiver with S-bus to start flying. None the less, I am already piecing out my gear to get into FPV. I have my Ground station pelican case, Monitor, and am choosing my Video RX,TX. As for the camera, I've decided to buy the PZ02420 and the CMQ1993X from securitycam2000. I am also thinking of getting a gimbal to mount one of these cameras to my quad, Specifically this brushless motored RCTIMER 2-Axis gimbal . My first question is, Can someone assure me that this gimbal is compatible with the DJ NAZA FC-Gimbal system, and that I do not need to buy the Gimbals control board(sold separately) or a different PT/gimbal. My next question is, after seeing how gimbals work to keep the cameral centered at all times, doesn't this make knowing the orientation of your quad/multi rotor during flight hard to know? Wouldn't it be an issue not know how "nose in" or "nose back" your quad is when your video view is always stable and straight? I am assuming that during FPS flight the camera on the gimbal is the camera you are watching on the video feed. So I guess what I really want to know is if during FPS flight, this isn't a problem or is it that most are using two cameras, one to "fly" by and another camera on the gimbal only used to record video??? If this is the case, Then perhaps I don't need a gimbal at the moment, since I am not planning to record flights just yet. Maybe I'd just want a Pan and Tilt with head tracking? Does head tracking mess with orientation on a Multirotor? FINALLY, If and when I do get into recording flights, and 2 cameras are used, one for flight and one to record.... this mean each camera needs its own TX, if so will I need separate two separate RX systems on my ground station one that sends the signal to my flying/view LCD, and one to say a DVR such as the DV02 that foxtech sells? What is the best/easiest way of routing two video signals in this situation? Is my thinking straight here?-----------------------------------------------------------------------Thanks, Chris. P.S for some reason my keyboard enter button doesn't work on this board.
