Motopreserve
I began documenting this build with the frame assembly, which can be seen over in the review section. Of course, the build just starts with the frame, but I realized I had not been updating my progress, and follow-up thoughts to the choices I made for this quad...
It's been about a month since I first put the frame together - and finally some weather worked in my favor, and I was able to get out to the field for some flying. More on that tom come...
First thing I needed to do was get all the components onto the frame. I had decided to go with the SunnySky V2816-1250kv motors. The V-Series is pretty sweet, with pre-cut shaft, and extra long motor wires (600mm, no bullets). The quality of these motors in your hand already feels better than the cheapies, and once you get them installed, there is a confidence they inspire. I haven't used any other super-high end manufacturers yet (T-Motors, Avroto etc), but these felt pretty damn high end to me.
I got all the ESCs and wiring laid out and installed. The fit in the "dirty" section of the CineTank is slightly tight for the f-30a speed controllers I used, but they ended up fitting nicely.
Once the basic parts of the frame were together, the SiuperX was installed. In the photo below you can see the side-view with the SuperX tucked away inbetween the 2 clean section plates. The pink rubber balls are to isolate the dirty and clean sections, removing motor vibrations from the clean section where the camera will sit.
Flying Cinema recommend 8" or 9" props. Once I got the 9" on there I was a little worried that they came mighty close to the frame. But when you peek a little closer - you realize they cut the frame plates specifically to allow for these size props.
Everything at first has been somewhat temprary as I waited for some cool parts that will add to the build quality. In the photo below you can see the GPS puck, which is HUGE! is just strapped to the top plate with zip-ties.
Stay tuned for updates...
