holco
New project for a Heavy-Lifter camera platform.
The objective are,
Multiple system use, such as, Mikrokopter with the V2.0 ESC's / OpenPilot / KKuk / and others.
Hexa setup, + and X mode.
5S setup with one 8000mAh lipo for long efficient flights.
Easy removable 20mm carbon arms with integrated power and led plugs for easy transportation in a custom case with foam padding.
Carbon 180mm frame and carbon supports for the Avroto 2814 short shaft motors.
Compact Wire Rope Isolators (diy).
Diy roll/tilt gimbal (AV-200 look alike).
Good looks!!
Dimensions test for the MK V2.0 ESC's mounting holes,
Production of the Avroto supports in 2,5mm carbon,
http://www.youtube.com/watch?v=QORE_zQUeZk
The results,
The objective are,
Good looks!!
The results,
