So I finally got to try out my quad for the first time today and cant figure out what the issue is. It's an all stock Naza F450, stock ESC's stock motor's with a 4s 5000 mah LiPo. I did the GPS calibration successfully the LED shows no errors and I have the best signal to the satellites. I've balanced the props which are DJI 1038 props, the FC is not upside down and from what I can tell there is minimal vibrations. My gains are set:
Pitch 150
Roll 150
Yaw 100
Vertical 105
Atti Pitch 150
Atti Roll 150
My issue that I am having is I can't keep it flying, no matter what mode I'm in. I start of in manual mode and it will allow me to take off and if I either keep it in Manual Atti or GPS mode, it doesn't matter for some reason I can fly to whatever height I want but then when I try to hover or anything it won't stay up at all. My quad just starts dropping even if I'm at full power and then when it gets to the ground it won't go any higher than a few inches. If I power down the motors and start them up again I can do pretty much the same thing but I just can't get it to stay in the air
Pitch 150
Roll 150
Yaw 100
Vertical 105
Atti Pitch 150
Atti Roll 150
