firmware 5.12 and faisafe question
conprot
when you activate the two position switch from standby to start should the U channel slide in the assistant sofware move to Failsafe ?
any help will be appreciated
Tahoe Ed
Mine does not. When I had it set up with a mix on the Tx it did. Looks like it is hard coded into the firmware.
Totality
Out of interest, how do you find out which version of firmware is installed on the Naza? Does the assistant tell you and how do you know if new versions are released, does DJI have an area on the site showing releases?
