photobobga
Using a DJI NAZA controller with GPS? Are you having unstable flight problems? This post might helpful. When measuring/finding the location of your aircraft's center of gravity try this procedure; configure your aircraft with a full flight load. Attach a string with a light weight (like a plumb-bob) to one of the 'arms' near the motor and then pick it up by that 'arm' (at the end below the motor) and let it swing freely without interference. Once the plumb-bob settles measure the distance from the plumb-bob to the center of the aircraft where your NAZA should be mounted. My measurement was 4 cm .vs -12 cm. The dealer and several other NAZA pilots told me to measure the distance from the top of the GPS antenna to the NAZA. Lesson learned.
Best,
Bob
Best,
Bob
