hi all: looking for some advice or confirmation here. my batteries (a pair of century 6S1P 5000mah 40C 22.2V 6S LiPo) were only taking about 2500mah per charge (according to the readout on the hitec x1), so i adjusted the voltage limits on my s800.
the copter is as follows:
takeoff weight is just about 6kg/13lb. the CG is dead in the middle front/back and left/right.
fully charged and just sitting on the ground, the assistant registered 25.3v. hovering a few feet in the air it was showing about 24.2V, but varying by ±.2V. is a voltage drop of 1.1V normal? seems a little high.
i adjusted the settings to the following
when the second level warning hit, i charged the batteries and the charger showed 3,948 MaH. 20.6V seems very low to have only then received 80% charge. is that normal?
finally, the charger is set for up to 6 amps, but only charges as 2.3 amps. it takes 1.5 hours to fully charge one battery, so 3 hours total. long time.
i have noticed that the century 6S1P is fairly heavy for the rated capacity - there are other batteries which have specs 25-30% better, so i might go to a different type of battery, even slightly lower capacity ones to save some weight. any comments on maxamps or thunderpower relative to the century, which i didn't personally choose?
thanks in advance for any advice! i've got in about 30 flights so far, flying 90% of the time on attitude. no catastrophic crashes. the main challenge has been unpredictable winds and maintaining control when the copter is too far away to really see which direction is which.
DJI S800
DJI vibration absorber mounts
DJI folding compass mount
DJI bluetooth LED
DJI WKM
two century 6S1P batteries mounted symmetrically, connected with XT60 y-cable, the second on an additional DJI battery mount tray)
Nikon D810 on a simple fixed custom mount, with either 20mm f/1.8 or 35mm f/1.8 lens.
DJI bluetooth LED
DJI WKM
first level protection no load 22.5v, loss 1.1v. (loaded 21.4v)
second level projection no load 21.7v, loss 1.1v. (load 20.60v)
first level is set to "LED Warning" and second level is "descending."second level projection no load 21.7v, loss 1.1v. (load 20.60v)
