A star-level camera is a camera that displays a clear color image without any auxiliary light source in low light conditions, usually in a starlight environment.
According to the definition of standardization, the security industry currently divides the front-end cameras into four levels: cameras with general illumination greater than 0.1 Lux are called ordinary cameras; cameras with illumination ranging from 0.1 Lux to 0.01 Lux are generally called moonlight cameras; The camera, known as the starlight class, has an illumination range of 0.01 Lux to 0.001 Lux. When the illumination range is below 0.001 Lux, it achieves ultra-low illumination of "Super Starlight".
The Thyea N30L from MMCUAV is a high-precision three-axis gyro-stabilized head that uses a standardized interface for unmanned mission load. The PTZ is equipped with a 30x optical zoom camera that combines star-level night vision and high-definition color.
This camera can switch between color mode and night vision mode. The 2 megapixel HD color camera with 30x HD zoom can work regardless of day or night. In night vision mode, it can also automatically detect light changes. If the light is too dark, it will automatically turn on the 500-meter laser filler, follow the camera zoom for laser fill, and clear image. And with the ground station system, target tracking can also be achieved.
Starlight level night vision sensor and laser fill light
30x HD optical zoom
Target Point Tracking
Switch between Color Mode and Night Vision Mode
So, if your drone is equipped with such a camera, you can take the photo you want, day or night, so what do you think of this camera? If there is anything you want to know, you can leave a message below.
30x HD optical zoom
