Extending Motor leads - Is it OK to Do ?????
jhardway
Basically, I am in the middle of building my heavy lift Octo, and when I mounted my new motor the power cables are coming up about two inches short of what I need. In the past I have read some stuff on the web concerning the length of motor power leads and that the can cause some problems.
If anyone could cherp in I would appreciate an help in this area.
My motors are the Tiger 4012 340KV, ESC Maytech Opti 45amp, the motors power lead are 18gauge. if you would like to see the size issue I am talking about you can look at this thread.
http://www.multirotorforums.com/showthread.php?10145-Tarot-IronMan-1000
Basically the arms are 420mm while the motor leads may be around 450mm. In my case to keep everything clean, I just needed to get another inch, on the leads for it to work, I have some other ideas where it will work fine I just want keep it as clean as possible and I feel the other way is not the optimally the best way to get there.
cheers
gtranquilla
RadioActive
High motor rpms require higher electrical frequencies...... some frequencies tend to reflect back from the motor into and/or thru your ESCs.
This is called EMI or RFI (electromagnetic interference or radio frequency interference).
ESCs with opto-isolation eliminate the risk of motor noise reaching past your ESCs towards other electronic components including GPS, radio, video etc.
The leads from your MR controller to your ESCs should be as long as possible so that you do not have to lengthen your motor leads to the ESCs.
The alternative is to use emi/rfi shielding in the form of toroids, shielded cables or an airframe shield made of carbon fiber...... but this method adds weight.
cheers
