HI Ovdt,
andreas answers some questions in the text below. The question/answer about the possibilities to use the 4120 axis puzzles me. I think he is stating that for such motors the current Hercules wont work ?
Guys,
Quote
1) Do you talked with MK staff to try a total integration with MK parameters in the mk tool, for example ?
I talking about temperature, lipos voltage, motors rpm. Doe we already have this ?
Not yet, honestly i am not sure if MK wants to cooperate with me or if i am only one bad guy with cracy ideas...
About features: When you read my moto below, it is "less is more". Means the less functions you have the less problems you will get. The Herkules II design concentrated mainly on his main job: Driving BLDC motors, and this as good as s possible. But anyway, currently i thought already about some usefull features:
1) Voltage measurement: already build in, readback possible by I2C, so if 7V5 is going to FC, no additional VBAT is needed. Only some one has to update the MK-SW if he wants to read out more from Herkules.
2) Motor rpm: in Firmware available, but not yet available in I2C. But can be easily brought in if needed
3) Temperature: As it makes no sense to have on one board 4 temp-sensors (they will read the same pcb-temperature) i am thinking of implementing one stand-alone I2C-temp-sensor on pcb which can be read out indepentely of the controllers.
4) Molex Connector. Don't know yet if i should implement this. Has some benefit, no soldering in FC needed anymore.
Quote
2) Can we expect a octo and hexa single board?
Currently a octo-board makes no sense for me because of
1) Connection of 2 Herkules can be easily done by Micromatch-connector and is not limited(i know from a guy who uses 4 x Herkules II to drive a 16-motor Kopter).
2) Main reason: Have no time for this right now. This will cause a lot of effort and the benefit is not so high.
3) But i can think of assembling only 3 of the 4 ESCs for an Hexacopter or so. This will bring down the price also a little bit. But main costs are currently the price of the PCB + assembling costs because volume is too low right now.
Quote
3) Can we expect a "Heavy Duty" board, with capacity for 4120/20 series Axi motors (quads / hexas and octos) ?
Large capacitors, thick force lines and what more you need.
All the community is waiting for a more secure system to lift $ 2.000 - .000,00 camera gear.
We have to many problems with I2C.
I do not care about some buck$ more for this
Yes you can. But when? I am working for a longer time on the concept of a big ESC with "industrial standard". Higher power, improved diagnosis and protection (current measurement in each motor phase), 8-14S capability, Error correction of communication, redundantacy and and and... but:
Who will pay for the development time? For this i would have to quit my job or my wife quits me ;-)
Quote
4) Can you provide a star I2C distribuition config in the future OCTO/HEXA boards (prevention of a general I2C failure if a isolated BL went bad)?
Do we already have "STAR" lines for I2c in your boards ?
Within this board i see not the need for this. Main reason for I2C-errors are ground offsets caused by high currents an voltage drop across long distance I2C. With this concept, having all ESCs close together and very close to the FC, we have no ground bouncing issues any more. All my I2C errors are gone since im using this quad-controllers.
And as i wrote: I did not design the ESCs to be destroyed. I expect that they will stay alive because a most of destroying root causes are gone.
Quote
5)Do you know how comercial potential do you have in your hands ?
Try to improve your logistics, you are going to start a bussines.
Do a site with a PayPal paying option.
I appreciate if you see also the benefit of this Design. Even if manufacturing cost is a bit higher than stand-alone ESCs, the safety advantage and build-up simplification is much more worth then a few bucks of money.
Honestly, the story currently consumes too much of private time. If i don't find a possibility to finance this hobby, it will die.
I will see if some one will be interested in this design (and currently it seems so ;-)... I do not know if i really want to comercialize this story. It will have a lot of consequences...;-)
_______________
