gomotomoto
Yesterday, I toasted a brand new 4S 5000 mah 35-70 while setting up the naza (not flying). Something sucked out voltage FAST. Not sure how to troubleshoot so looking for some advice. I'll layout as much of the situation as possible, maybe someone can help me track down the issue:
Putting together a dji 550 with the following specs:
1. DJI Flamewheel 550
2. Aerial Media Pros Heavy Lift Kit
3. Naza V2 w GPS
4. Zenmuse h3-2d
5. iosd mini
6. TS832 5.8 32CH VTX
7. LED strips (2 red, 2 green, 2 blue) for orientation
8. FRSKY X8R rx
9. home made retractable landing gear
As mentioned above, I had my Lipo at storage charge around 3.75/cell & used it to set up the 550 with the naza assistant on the PC. I did the near identical thing with my 450 setup (stock, no accessories other than a few LEDs) and I was able to spend well over an hour powered up on the Lipo without going below 3.7/cell, so I don't think setting up the naza with the craft idle draws much current. So, I'm pretty sure I have an issue somewhere here's how I have everything set up:
• the craft powers up and everything looks operational, I figure if there was a short somewhere, it would have destroyed something but all seems ok, except there's a massive current draw somewhere.
• Naza power is simply soldered into the power distribution board.
• Zenmuse is also soldered to the + - on the power distribution board. iosd mini cable is tied into the zenmuse 3.5 jack line, wiring looks correct per the manual. This is a wiring harness that I had to make, not plug and play
• The TS832 say it can handle the juice from a 4S, so i've soldered the power wires direct to the power distribution board. I'm suspect of this because the VTX was noticeably warm. Is it possible, powering this up direct to the 4s is causing the issue, maybe it needs a voltage regulator? Still seems weird.
• I have alot of LED's connected, but I don't think they draw too hard, do they?
• landing gear is operated by two powerful little servos but didn't retract them much at all.
I'll have to get a new battery now, but don't want to trouble shoot with a 4s, so will get a smaller (cheaper) lipo to do my troubleshooting & naza setup with. Any suggestions for a lesser battery to set up with? Maybe I should get a second battery to power just the VTX?
Any help appreciated. I'm kinda stuck at the moment.
3. Naza V2 w GPS
4. Zenmuse h3-2d
5. iosd mini
8. FRSKY X8R rx
