helloman1976
Ziptie Relocation Expert
Hey, just working on building my Eagle Tree Tracker and I THINK I have it working but want to confirm with those who know for sure and see if this behavior is expected. Ok so I've noticed a few things, first when the tracker loses "telemetry" it beeps for a while and then seems to return to "50%". Also, the tracker doesn't seem to be perfect as it seems to a take a generalized guess as to where your model is. I setup all the degree angle in the tracker setup so 0, 90, 45, 315 and so on. My house faces 315 degrees so I used a compass rose based on that. I set the tracker up for anything beyond 5 feet is when it starts tracking. I'm using diversity as well. It seems to track the model ok when the model has good GPS. Couple questions, is all of this normal behavior Is there anything I should or shouldn't do with the tracker setup or the configuration? Any lessons learned type information? What servos is everyone using, the ones from readymaderc seem to be ultra weak and will certainly need to be replaced. They can spin the tracker if there's ABSOLUTELY nothing in the way but one wire bumps against, not catches, the camera mount and it struggles whereas it should blow past it. I checked to see if there was any mechanical binding and aside from the tilt wire bumping the tripod when it swings by there was nothing in the way or hanging up. Anyway, thought I'd check with the crew before I put this bird in the air. Thanks all!
