Hi guys,
So was out today for the first time in long time. finally some good weather for flying, 3m/s winds no gusts.
Set everything up, got gps, started the camera and opened the throttle(att), the MR started to wobble a lot(skids on ground) took off and it was stable when of the ground and then turned on gps.
The MR started to drift all over the place! White LED started flashing and could barely land it safely.
So I've had this white LED thing before but nothing really happened apart for it flashing.
I've bought the WKM because it should be a stable platform and with good gps lock.
Been working on this thing for some time now but it had never really been stable without manual corrections.
How can you best align all the stuff? IMU with the frame, IMU and GPS. It seems that there is a problem with the GPS unit to me but what can it be? I had the IMU and GPS closer to each other and that worked better. Now have it on a small pole as seen below. It is also shielded by coper plated PCB. The IMU is stuck with double tape with 0.5mm foam and is fixed securely, can't dance around.
Now going to update firmware to 5.02 to see if this has any effect.
View attachment 2333View attachment 2334View attachment 2335View attachment 2336View attachment 2337View attachment 2338View attachment 2339
Sebas
Sebas
