ross_badger
For sale are white and black domes for DJI F450 & F550 frames, as well as Rusty's UAP1 & UAP2 frames. The cost is $12 plus shipping for a standard hemisphere dome or $16 plus shipping for a hemisphere dome with a removable GPS sensor protection/mounting pocket.
You can order online at www.BadgerFly.com, or PM me if you are interested.
DJI F450 frame hemisphere dome dimensions: 135mm inside diameter, 68mm from flat flange to inside top of dome, 158mm diameter of flat flange. Weight: 59 gms
DJI F550 frame hemisphere dome dimensions: 152mm inside diameter, 76mm from flat flange to inside top of dome, 185mm diameter of flat flange. Weight: 75 gms
UAP1 frame hemisphere dome dimensions: 134mm inside diameter, 67mm from flat flange to inside top of dome, 161mm diameter of flat flange, 5mm vertical flange lip. Weight: 64 gms
UAP2 frame hemisphere dome dimensions: 174mm inside diameter, 87mm from flat flange to inside top of dome, 208mm diameter of flat flange, 5mm vertical flange lip. Weight: 100 gms
0.093" thick Hi-Impact Styrene domes are very strong and are paintable.
Hemispherical domes can be purchased alone or with an optional GPS sensor unit pockets. The pocket fits perfectly at the top of the underside of the dome to protect the sensitive GPS unit or other electronics that need to be mounted above the flight control board. It can be attached with velcro or with nylon or aluminum screws (steel screws will affect the GPS signal). The mounting hardware is not included. Styrene plastic will not affect the GPS signal.
View attachment 12046View attachment 12048View attachment 12047View attachment 12043View attachment 12045View attachment 12044View attachment 12052View attachment 12051View attachment 12050View attachment 12049
