I build a Heax rotar with WKM V1 Using T motor 2216-12-kv800 APC prop and T motor 30A Esc with 2 3s battery I was flying it today the led light was flashing normal then it was flashing red in few min but the battery was full it went 20 meter up and going up very steady then when I try to bring it down I noticed that it is kind of rotating and became unsteady and suddenly it crashed to one side destroyed my beautiful $500 gimbal and ... do not know why has any one else had the same issue any one else had the same issue
I do have telemetry system so the voltage was 3.96 for each cell after crash in both batteries so no low voltage involved here what exactly happened when i start to take off it was flying but not going to high and red was flashing and it was kind of landing by itself even the throttle was over the meddle then i put te throttle to 80 then it was keep going up it was very steady in GPS mood but once i try to land still in GPS mode then it it lost the steadiness that it had and not responding to Tx very well it was going to one side and other side and small turn and then crash to one side there was no prop was broken in the air only in the ground I assume that it could be some bug in GPS I am using the GPS that has two black side also I was told that since I use T-motor ESC might need some programming if so do u know how ???
