DJI WK-M + X650 V4 + Sony Nex 5n w/h 16mm lens ??
kuau
would this combo have enough lift? Or do I really need to be looking at a hex?
I'd this combo would work what would be an ideal camera mount?
thanks
steven
you will probably want more. even my v8 wasnt enough to happily lift the mount and nex5n. It WILL lift it and more but not safely with the comfort you will have using a larger machine. The other downside to Xaircraft is the flexible plastic used on the gear shakes a lot. When I switched to a rigid body i noticed much better results with the video. It is very durable and can take abuse but not ideal for semi-pro results. Its a good place to start though for cheap.
kuau
irisaerial,
thanks for the info.
sounds like if I want to use my nex 5n, what frame and camera mount would you recommend?
