ZAxis
We've been piling on the hours since the beginning of March so its time for a service. Generally most things have stood up well to being travelled from the sub tropics to the arctic circle, from sea level off a boat to being trundled up ( and down) several mountains. We've had to repair a damaged undercarriage leg after a transport accident. Its instant arm fold up and down has been a major asset. Early on we flagged that the motor isolation grommets were a weak point and it has turned out so. Getting new grommets meant ordering from Hong Kong as few dealers seem to stock them. We've had to replace all the grommets since they all showed wear. All of them were worn through on the web between the upper and lower halves which means the bolt ends up rubbing directly on the carbon fibre motor mounting plates. This seems to negate at least some of the vibration isolation. Even after replacing the grommets some mounts seem to have more slack in them than others. However the footage from the ZenMuse doesn't show any vibration, which is good but we'd much prefer to have much lower vibration in the first place. Some grommets were replaced a couple of weeks ago but because some of the bolts were over LockTite'd we had to wait till we got some decent Torx 9 wrenches to replace the others. In that time some of the newly replaced grommets had worn through again, we've replaced those once more.
We found loose screws on the lower half of one arm pivot block and on the locking arm pivots of the retractable undercarriage . Re LockTite'd those. Replaced two prop blades, adjusted some prop bolts to reduce slackness and that's about it.
Be interested to hear other people's experiences.
andy
andy
