redridinghood
Well DJI is officially crippling it's WKm series with a Naza gps upgrade.
http://www.rcgroups.com/forums/showpost.php?p=21617245&postcount=1
The only real difference that I've seen is the WKM will hold altitude better than the Naza in FFF, otherwise they perform much the same. I've flown two different frames, a quad and a hex, each using the same WKM and Naza and the actual flight performance difference was very tiny other than the Naza lacking GPS.
I have an F450 with Naza that I use for limited range FPV mainly due to the 100 mW video TX on it. With the GPS upgrade, especially if it has RTH (don't care if it autolands as long as it comes to back home), I plan to upgrade to a more powerful video TX and go for a longer range. If it loses the signal from the TX in my hands I would expect it to start flying back to where it started from, if it can do that then I'll sell my second WKM in favor of another Naza or two.
For full GPS features and functionality I have 3 MK stacks with full GPS/Navi and the WKM on my Cinestar, I don't need all the bells and whistles on the lower end, position hold and RTH for a reasonable cost works for me. On the other hand, I'm not going to spend an additional $300 or more per Naza just to get those two features, not when the Rabbit board is available with GPS for under $200.
Have you tried out the rabbit board? I just googled it - just curious as to how well it works.
thanks,
Benjamin Rowland
