DJI Lightbridge - 2.4G Full HD Digital Video Downlink
Quinton
DJI Lightbridge (Am I dreaming?)
Is this for real, if so it will be the most important product DJI will have brought out to date!
· 2.4G Full HD digital transmission
- Digital video transmission, input supports up to 1920 * 1080 @ 60fps , output up to 1920 * 1080 @ 30fps ;
· Distance
- Use 2.4G RF technology, transmitting power 100mw (CE and FCC certification);
- Ground terminal with 5dbi omni-directional antenna (standard), measured the effective transmission distance of 1.7km (1.05mile);
- Ground terminal with 14dbi directional antenna (optional), measured the effective transmission distance up to 5km (3.1mile);
• Multiple video input and output formats
- AV input;
- HDMI input;
- USB 2.0 Full HD video output: IOS, Android and other mobile phones, tablet PCs do monitor via USB connection using;
- HDMI HD video output;
· Built-in remote link
- Downlink and uplink remote video link system while working at 2.4Ghz;
- Ground terminal via remote control coach to get the remote control port data sent to the client through the sky uplink, downlink synchronization with the video link, without disturbing each other;
- Ground terminal controller supports two simultaneous input Lu Yao, were used as aircraft control and PTZ control, the sky receives transmitted to the master via DBUS;
• Immunity
- Uplink frequency hopping (FHSS) + Spread Spectrum (DSSS) technology, high transmission stability, strong anti-jamming capability;
- Downlink MIMO multiple antenna technology and using OFDM modulation, with advanced algorithms to effectively improve the stability of the system data bandwidth and complex environment, improve the dynamic performance of the system;
- Real-time monitoring of each downlink channel interference state, dynamically select the best channel operation (up to 8 image transmission channels);
- Same time and can support up to eight devices simultaneously sets Lightbridge;
• Low Latency
- System maximum delay 80ms;
• OSD function
- Built-in OSD function, with NAZAV2, WKM, A2 use when no external IOSD, information overlay function can be realized;
• Bundled flight controllers
- Equipment must NAZA V2, WKM, A2 used in conjunction with the master.
• Multi-slave mode and Information Security
- End single sky and simultaneously work with multiple ground terminal (only one ground terminal to transmit control data, the device can only receive the rest of the video);
- Data encryption transmission, only after the ground terminal on the frequency authorized to receive video data to ensure information security;
• Large-capacity rechargeable battery and the external
- Built-in 4000mAh high capacity ground terminal battery, the device can work for 4.5 hours;
- Standard charger or 3s-6s battery can be charged, charging only 1.5h;
- Battery power LED visual indication;
- Through the USB external mobile devices, providing the charging function for mobile devices, an external device to extend the use of time;
Second, Specifications
Video Input HDMI, AV, DVSB
Supported formats (HDMI) 720P50; 720P60; 1080I50; 1080I60; 1080P25; 1080P30; 1080P50; 1080P60;
Supported formats (AV) PAL25; NTSC30
RF parameters 2.405 ~ 2.4835GHz, comply with CE, FCC certification
Interface (ground side) LED lights; power switch; charging port; USB 2.0; HDMI; remote control inputs (two Luyao controller input)
Interface (Sky end) LED lights; DBUS; HDMI; AV; DVSB; keys for frequency
Material Aluminum
Power supply (ground terminal) DC power input 11 ~ 26V; built-in lithium battery; Consumption: 6W (no external USB device), 8W (external USB device)
Power (Sky end) DC power input 11 ~ 26V; Power consumption: 8W
Dimensions (ground side) 125 * 89 * 20 (mm)
Dimensions (Sky end) 67 * 47 * 20 (mm)
Weight (ground side) 360g
Weight (Sky end) 70g
Performance than several million existing digital image transmission system, price to be determined, is expected to price and A2 considerable time to market is expected about a month;
After ten specific price and time to market announcement ~ ~ ~ ~ ~
deluge2
Quinton
To give you an idea of what is available at the moment up to 2000 feet and 1 ms latency, Paralinx Tomahawk started at $6995, now I see its $4300..
Will be very interesting to see what DJI come up with, and to see if it really is uncompressed (I cant imagine it will be) but who knows, times are changing.
maxwelltub
For zero, or close to zero latency I dont think you can compress it. I could be wrong. Anyway this looks like an awesome product.
Benjamin Kenobi
Easy? You call that easy?
That....is....awesome! It will revolutionize the industry! So many industries are looking for live HD feeds. This, combined with a new generation of battery technology, will give us incredible capabilities!
Quinton
That's why it will be interesting to see exactly what they have done, there has to be some new implementation here to transfer HD at this distance, maybe using wimax or something.
Just hope it will be legal in most countries, not sure I would buy version 1 of this thing, especially with DJIs record of fixing things after release.
Transferring HD over a long distance is no mean feat.
Tahoe Ed
The RC control and the HD video link are over the same 2.4gHz channel. You can control the copter and the camera with a second Tx all together.
Benjamin Kenobi
This is all pre-release stuff. No point in asking real questions at the moment. DJI will release the specs when they are ready.
PS - What's the risk? Video on one channel set and RC control on another set. It seems safer than having two competing systems.
maxwelltub
No point in asking questions? really? Ed might know the answer as he is DJI forum support.
The reason I am wondering about the 2.4 video and transmitter is because you would not use this set up in any other circumstance. Perhaps if they are using the same controller board it can make sure to prevent interference between the video RX and controller TX?
eyeball
I was looking at this new product Lightbidge as an app on a phone this afternoon, seems very interesting, its early days but I'll keep you updated.
When when when and how much.
I'm using the 5.8ghz boscom rc805 system now and would like to upgrade to a better system asap.
any advice on better system be appreciated please.
Jamie
DJI Lightbridge will start shipping during February 2014. We will only have 500 units available this month so get your pre-orders in as soon as possible.
DJI Lightbridge is an all new revolutionary 2.4G Full HD digital video downlink. DJI Lightbridge offers extremely powerful equipment packed into a small and light-weight form factor. By offering 1920 x 1080p@30fps video data transmission from up to 1.7km (1.05miles) away, it's the ideal solution for the professional aerial photographer and FPV users. Set yourself free and remove the limits from low definition analog video transmitters.
Features:
-1920x1080@60fps input and 1920x1080@30fps output
Extreme Long Distance Transmission
-Less than 100mW ground unit transmission in full compliance with CE and FCC certification
-5dBi omni-directional antenna offers an enormous distance of up to 1.7 km (1.05 miles)
-Optional 14dBi patch antenna boosts transmission distance tremendously to 5km (3.1 miles)
Multiple Input And Output Connections
-AV input
-HDMI input
-DJI Zenmuse gimbal input (Digital Video/Power Supply/OSD Data)
-HDMI HD image output
-USB 2.0 image data output for iOS and Android phones and tablet synchronization
Built-in Remote Control Link
-Uplink remote control transmission and downlink video work simultaneously on 2.4GHz.
-Remote control data travels to the uplink via the TX-Thru Port at the same time that video is streamed back down all without interference.
-Support for two remote controls: one for flight control (10 Channels) and the other for gimbal control (6 Channels). Control signals are received in the air and then transmitted to the flight controller through D-BUS.
-When used with a non-2.4G radio transmitter, video only transmission operation is supported. The DJI 5.8G radio transmitter is recommended.
Strong Anti-Jamming Technology
-Frequency Hopping Spread Spectrum(FHSS) + Direct Sequence Spread System(DSSS) technology is used for uplink transmission to enhance stability and offer anti-jamming capability.
-MIMO multi-antenna technology and OFDM modulation methods along with advanced algorithms are utilized for downlink transmission to enhance data bandwidth, improving dynamic performance and increasing stability even in harsh environments.
-Channel interference is constantly monitored during downlink transmission with automatic switching between 8 channels for the best possible signal.
-Up to 8 downlinks can be connected for parallel streaming and work independently without interference.
Low Latency Transmission
Maximum latency of up to 80ms
Built-in OSD (On-Screen Display) Function
-No additional equipment required for OSD functions when used with A2/WooKong-M/Naza-M V2 flight controllers. Flight parameters will be displayed onscreen.
-OSD functionality can be turned off via mobile software for HDMI and iOS/Android Output.
Must Work With DJI Multi-Rotor Flight Controllers
-DJI A2, WooKong-M and Naza-M V2 flight controllers
-Phantom 2, with DJI 5.8G radio transmitter.
Multi-device Operation Mode, Stable and Reliable
-A single air unit can transmit to multiple ground units sending video to multiple screens. (Only one of the ground units can send a control signal while additional ground units will only be able to receive a video signal)
-Encryption ensures only authorized devices can receive data which can be programmed via mobile device software.
Built-in High Capacity Battery
-Ground unit has a built in high capacity 4000mA battery offering up to 4.5hours of use per charge.
-Rechargeable through the supplied charger or via a 3S~6S Li-Po power battery.A full charge takes approximately 1.5 hours.
-LED battery level indicator
-Also functions as a USB charger for mobile devices prolonging the life of peripheral equipment.
Electromagnetic Interference Shielded Structural Design
-Aluminum alloy casing
-Extreme internal and external shielding for interference protection.
