AirShooter
FlyCam UAV
Hi all,
I just finished a hex build using the E800 system from DJI. First off these are the most quiet motors ever!
Now for the problem.. Power it on ESC's sound off, all esc led's good, take off, fly's awesome. Now the problem. Once I land if the flight battery is swapped out, or even just unplugged then re plugged, I get an esc error tone, sometimes on #6 sometimes #4 and that motor will not start. It was also doing a really odd thing 50% of the time it has the ESC error my landing gear would go into retract the minute I plug in the battery wtf? have to grab it quick before it puts the camera into the ground.. flip my gear switch which now makes it backwards. So then I have to switch off the TX, put the gear switch in the correct position and try again. after two or 3 or 4 tries, it just starts up and fly's fine, I've checked all wiring and solder connections all are good. this is with a Naza V2 FC any ideas?
Thanks!
Thanks!
