BorisS
Hi guys got a DJI A2 controller for test purposes today to see what i can do for me.
Installed it today on my X8 Herkules Build.
General to the casing it is obvious that its higher quality than the WKM plastic cases that were used before !
View attachment 13665View attachment 13666View attachment 13667
judged from the size there also seems to be a hardware upgrade to the GPS/Compass module ! Also the cabling on the modul has some sort of ferreting component to it !
Cant say a lot yet just a fast intallation up to now, but some points i liked !
1. Channel mapping finally ! The limitation of only having 7..9 (whatever it was) channels that can be assigned are over. No matter what system when single cable connection so S-bus PPM i guess up to 16 channels can be used. So no more I want to remotly tune my gains and than i dont have a channel left for IOC and a go home swtich etc.
2. Finally also a motor test feature, which i guess is also offered now for the other hardware versions just a question of the FW. But the positive, fast check if all motors are connected correctly via PWM cable.
More to come. Have to play arround a little and take the bird on a spin this weekend !
Boris
Boris
