hexacop
HexaCop
Sure the Gopro is not the best choice for panoramic images but it works reasonably well.
This is my workflow for aerial panoramas:
<object classid="clsid<img src=" http:="" www.multirotorforums.com="" images="" smilies="" biggrin.png"="" alt="" title="Big Grin" smilieid="3" class="inlineimg" border="0">27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" id="_360_krpano_id_103241" name="_360_krpano_name_103241" width="600" height="400">
<embed src="http://www.360cities.net/javascripts/krpano/krpano.swf" pluginspage="http://www.macromedia.com/go/getflashplayer" allowfullscreen="true" allowscriptaccess="always" quality="autohigh" flashvars="pano=http://www.360cities.net/krpano/external_embed/gopro-hd-aerial-panorama.xml&epd=http://www.360cities.net/data/embed/plugin_data/gopro-hd-aerial-panorama" height="400" width="600"></object>
Gopro HD aerial panorama in Oberbayern
If you want to produce good quality panorama like the one below, then you will need a better camera and some fisheye lens. This panorama was done with Panasonic GF1 and 8mm Lumix lens.
<object classid="clsid<img src=" http:="" www.multirotorforums.com="" images="" smilies="" biggrin.png"="" alt="" title="Big Grin" smilieid="3" class="inlineimg" border="0">27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" id="_360_krpano_id_971515" name="_360_krpano_name_971515" width="600" height="400">
<embed src="http://www.360cities.net/javascripts/krpano/krpano.swf" pluginspage="http://www.macromedia.com/go/getflashplayer" allowfullscreen="true" allowscriptaccess="always" quality="autohigh" flashvars="pano=http://www.360cities.net/krpano/external_embed/olympiapark-aerial-view.xml&epd=http://www.360cities.net/data/embed/plugin_data/olympiapark-aerial-view" height="400" width="600"></object>
Olympiapark Aerial View in Olympic park
- Lift off the copter at preferred height of 40-160m
- Enable GPS Position Hold
- Observe the Jetibox display and rotate the copter in 90°steps, trigger the camera and take 4 pictures (i.e. at 0°,90°,180°,270°)
- Tilt the camera to -90° and take the nadir picture
- Land the copter and turn it off
- Manually take 4 sky pictures at ~ 0°,90°,180°,270° pointing the camera up around 70° plus one additional shoot straight up 90°
- load only the aerial images
- Set Optimizer to Heavy + lens shift and enable the option automatic exposure mode
- Align Images
- Now you should get a spherical panorama (without the sky) You can further add CP and optimize it until you get the expected result. You may also want to mask out some parts of the pictures which should not be visible.
- After you are satisfied with the above load 4 sky images and move them manually to the proper position. Usually the Sunlight will give you a very good idea where to place them.
