Did I brickk my esc?
Zoedoggy
I purchased the E310 propulsion system awhile back and it seemed like the motors weren't spinning up equally at startup. They worked fine when given throttle. TheE310 kit came with an esc updater module. So..... I updated one esc to new firmware. Reenergized the system and that esc just beeped 3 beeps over and over with a yellow light flashing. Connected to Dji esc program and got a warning that the esc had the wrong parameters or something and to change the motor or esc. Then I found other forums where others had the same problem and Dji just gave some lame excuse and no solution. They did say you can't flash back to original firmware. Why give an updater tool in the kit if it just borks the system? Anything I can do to salvage this esc? Should I update the other 3 and hope they even out?
Zoedoggy
Update: I found a solution. Turns out I chose the wrong kv to upgrade to. The soution was to reflash to the correct kv. Updated all escs to 3.1 and all is good.
