Converting fatshark googles to ski googles
Macsgrafs
I'm about to mount my fatsharks in a pair of ski goggles...are there any prefered types of ski goggle for this or will any do?
Ross
it makes em so much more comftorable. I did it three times, finally the last time i was pretty stoked with the results, except the innevitable heat from the video receiver, only reason i gave em up. The first try i tried just cutting a slit in the lens like the others you see available but the screens wound up too far from my eyes, started loosing the perfrial vision they had, yada, yada. i tried a set of normal sized goggles and tried putting everything inside the lens, it all wound up too tight, the plastic frame was back to pushing on my face, etc. The third try i went with a ski goggle made for wearing with glasses. There deeper than normal and imo have better venting. All i did was use black spray paint over scotchbrited lens on the inside. put the lens back in and got all the pieces in there and had to do some shuffling to get the monitors as centered as possible without beating up the rest of the parts. I ran into one problem where fatshark sent me a part to fix video tearing and they had to come apart. By the time i got the glue and crap off, i had broken the antenna input on the board, pcb cracked in half, but luckily was the rx part you buy seperate for fatsharks and was $30
this is what worked for me
i.php
i.php
see how the monitor is offset, never noticed wearing them, but that's the whole trick, getting them big enough to make not noticeable
there is also this guy selling them, might look through for more refined ideas
http://www.fpv-plastics.com/FPV-Plastics/Welcome.html
ChrisViperM
...that's some serious ski goggles. Since you live in a pretty hot part of the world, did you never have a problem with the receiver board when you start to sweat...? Looks like the board is not protected.
Chris
Macsgrafs
Mailman is right, they hurt your head..you have to have them that tight that they hurt the bridge of your nose.
Kloner, thanks mate, the info is appreciated...I will check out that link as well.
Ross
my face never touched any of the parts. just the acumulation of heat from the rx made it kinda warm inside. i've read if you use an external rx with a wire going in it's alot cooler. I flew with them for about 3 months, then realized i liked being able to see it come and go as well, made a more easy feeling knowing which way to walk
These just got sold with the kloners 450 frame as a rtf fpv quad. hopefuly we'll see it around here shortly
forgot to mention, i had done this around easter. went by my local Big5 sporting good store and there was a 20' long wall 6' tall with goggles on sale, 50% off kinda stuff. these ones above were like $17. Best money i ever invested in something after the fact of spending the money to get something
