Finishing up my hexacopter build - time to wire up the Futaba 10J radio, R3008SB Rx & Naza M V2!
I've been scouring the forums, YouTube, Google, etc for the info I need on this ... and the manual, and I'm not finding the info I need (or, that I understand!)! First of all, if you have any recommendations for online resources, I’d greatly appreciate it.
Otherwise, here is where I am at on this, if you can provide any assistance directly related to the 10J/R3008SB and Naza Flight Controller.
My 6 ESCs are connected to the M1-M6 connections on the Naza. And, I believe that is the only connections for this end of the PMU.
On the other end, I have… A, E, T, R, U, X1, X2, X3
I’m looking to provide the basic/essential channel/functions (roll, pitch, throttle, rudder, etc) - I also need the mode (GPS, ATTI, MAN), Fail Safe, Gimbal tilt (VR), Camera Shutter Release & Retractable Landing Gear - I should have 10 channels total (right?).
Choices are - use S.BUS or 2 receivers, right? If I use S.BUS, do I simply connect 1 servo cable to from the 8/SB on the R3008SB to the X2 connection on the Naza PMU? If so, how do I connect/access the additional functions - gimbal tilt, camera shutter and retractable gear - does it matter which ch/position on the Rx? Would I have any other connections to the PMU besides the S.Bus connection?
Since I'm at 10ch, it seems the 10J will work for me - without stepping to the 14SG.
Any assistance would be SO greatly appreciated!! Hopefully this makes sense! I think I'm close!
