Coomkeen
I've done this once, but not sure I did it right.
Anyway, I've now rotated the GPS/Compass sensor to allow for magnetic variation, and also made changes to the main frame.
So a re-calibrate is called for.
Now swinging it around in the horizontal plane is fine, but turning the quad on it's edge, the manual says:
If it's the new vertical axis it surely must matter which way up you're holding it - nose down say, or side down.
OK, so I'm a thicko, but I get easily confused when looking too closely at sentences like that.
Just noticed that it does actually say "along WITH it's vertical axis".
Now I'm even more confused...
- Calibration in vertical: while green light is constantly on, hold your multi-rotor vertically and
rotate it along with its vertical axis,
