LordoftheCrabPeople
I'm getting out of MK and getting into smaller stuff. I was flying along beautifully today until I got a brief BL error and suddenly I could not control the chopper. It full throttled into the ground out of control. I think I had a motor wire bullet connector break off causing the copter to bank suddenly. Here's what I'm selling:
-Crashed CarbonCore 950 Hex frame that needs (2) of these: http://shop.carboncore.co.uk/epages...ops/es140672/Products/"Hexacopter Motor Ring" and one arm http://shop.carboncore.co.uk/epages/es140672.sf/en_GB/?ObjectPath=/Shops/es140672/Products/Arm380 to make complete again. Otherwise a complete frame with a stock landing gear that was never used. $200.
-CarbonCore Tall Landing gear http://shop.carboncore.co.uk/epages/es140672.sf/en_GB/?ObjectPath=/Shops/es140672/Products/LSAV130 that needs (8) of these to complete http://shop.carboncore.co.uk/epages/es140672.sf/en_GB/?ObjectPath=/Shops/es140672/Products/LSSH $200
-CarbonCore 950 Hex frame complete. http://www.rc-drones.com/H6-950-Hexacopter.php $350
-(2) complete Mikrokopter stacks, one with the ACC 2.2 upgrade and the other has the wires soldered ready for the ACC upgrade. Both stack fly well. One has a GPS shield (this stack was on the crash, I tested the stack with KopterTool and it's good to go). One stack is mounted to a CarbonCore plate but can easily be removed. $450 for the non-ACC upgrade stack, $500 for the one attached to the CarbonCore plate pictured.
-(2) Mikrokopter Hexa ESC boards complete and flying. One sustained damage in the crash and will probably need to go back to Quadrocopter for a remove/replace on the distribution board (this one was brand new 10hrs ago). Pretty cheap fix and have them check out the ESC's while they're at it. The ESC's look fine to me but lost a few of the heatsinks and I'm getting Error 17 now (one of the traces is broken through on the dist board). The non-crashed ring is in beautiful condition with silicone wire/bullet connectors soldered on and ready to go. $300 for the crashed one, $450 for the nice one.
-Graupner MX20 with MX16 receiver. Transmitter has a color FPV screen and 5.8 receiver attached. $400 for this.
-Xbee bluetooth and the MKUSB for updating boards. $20
-Grousehouse 2-axis gimbal with CSGShop Alexmos 2-axis controller. Amazing design that works beautifully with BlackMagic Pockets on down. Will throw in a single axis controller with 2 spare DOF sensors. Also has a custom landing gear with battery tray setup. The aluminum standoffs died in the crash so you'll need some standard standoffs to make it work. It will need some cheap 12mm carbon tube to make the landing gear legs as tall or short as you want. I will throw in some spare 12mm to get you going. Comes with a pair of 3s lipos and an HDMI converter with super flex cable if you are using a BMPCC. $200 for this package.
-Box of misc parts including (3) 5000mah 4S Hyperion batteries, (1) 6500mah 4S Quadrocopter brand battery, another stock CarbonCore landing gear, a roll of 50' 16ga silicone black wire, a whole pile of APC props from 10" to 16"MR, spare hardware galore, an exta 5.8 transmitter, and whatever else I find. This pile of spares will go with the choppers if you buy the whole as a package. Otherwise I'll sell individual spares as I list them out.
-(2) 6500mah 4S batteries from Vicious Teknology that are brand new and were flying on the crashed chopper. $150 for the pair with custom harness.
-(6) MK3638 motors. One got buried in the ground during the crash but I washed it off and it's actually in good shape (you will need to take it apart to clean it properly). $225 and they have brand new prop mounts on them.
-Hyperion EOS0730i charger with adapters for all batteries. $50
BONUS if you want it. I have a Pelican case that will fit most of this stuff including the chopper. It's brand new and I have a huge pile of "pick-n-pluck" pink anti-static foam that goes with it. I sized this case to go airline oversize. I paid 300 for the case and 100 for the foam. Take it for $300
Make me an offer on all this stuff. I'm tired of big multirotors and will be focusing on small format from now on. Some prices are flexible. $3400 takes everything listed above if you come get it. I can fit all of this in the Pelican case and ship it that way except the foam will have to go in a separate box. I'd say shipping that would cost around $60 total. If I sell off stuff I will update as I go.
