Recently, the People’s Daily published a video of a fire-fighting drone fire extinguishing on the overseas social platform. It can be seen that the drone quickly extinguished the fire with efficient fire-fighting equipment. This video has been praised by thousands of people, because China is the first country in the world to solve the problem of high-level fire fighting, and has a positive role in promoting high-level fire fighting.
As we all know, with the development of society, there are more and more high-rise buildings, and even more than 30 floors of residential houses are common phenomena. Once a fire broke out at a high level, the existing fire-fighting equipment could not carry out effective rescue. The most important reason was that the existing equipment could not deliver the fire-fighting equipment to such a high height. When the firefighters rushed from the inside to the fire site, it basically caused the fire. Serious property damage may even cause certain casualties.
The fire drone effectively solves this problem. First of all, the fire drone can directly reach the fire floor without ignoring the height, and the shortcoming of the load can be solved by carrying a high-efficiency fire extinguishing agent. For urban fire protection, MMC recently developed the APOLLO FB1 airborne broken window fire extinguisher, which was specially developed to extinguish fires in high-rise buildings or specific areas of the city. It uses an electronic quick-start trigger method to quickly break the window and enter the room after the fire-fighting projectile is fired. The backside is sprayed with dry powder to achieve full flooding and impact coverage. In addition to horizontal fire extinguishing, Corbet also has APOLLO FE3 fire extinguisher products, carrying a dry powder with a net content of 3kg, using electronic quick-start triggering method, vertical rapid spraying of fire-extinguishing dry powder, effective fire extinguishing range can reach 7m3, and can effectively protect people's lives and property in a timely and effective manner. . In addition, the drone has a huge advantage, can ignore the terrain factors, reach the location where the fire truck is difficult to reach, not only makes the fire fighting work faster, but also the point-to-point fire extinguishing greatly improves the fire extinguishing efficiency.
