1/ what do you use to thoroughly clean flux off?
2/ how's that joint lookin to the rest of you? me, unless i hear further objections and concerns, i think i'm going to go with it!
The pic 0193 shows a strange ground (black) cable soldering. It may just be the picture but it seems not as centered and not as well soldered as the others. Check it out. Otherwise, I see a big progress in the soldering and I am convinced that you can see it too. It looks OK to me as far as the pictures can revealed. You know, once soldered, give it a good pull and see what happened. You should always check your soldering for solidity afterwards.
You can clean the excess flux (gummy and corrosive indeed) with a tooth brush (use your mother in law) and regular rubbing alcohol (ethyl alcohol). The rubbing alcohol will dissolve the flux and you can wipe it off then with a kleenex or scott towel. It has to be wiped off because the alcohol will evaporate and the flux will show again.
When it is well soldered, physically checked and cleaned off, I personally use my hot glue gun and generously cover my connections with a good dab that stretch beyond the pad. This effectively isolate my positive leads, prevent element exposure and may even save the ship in the event of a breached connection. It can be easily removed and is transparent in nature, in addition to act as an electrical insulator.
Here you go now, ready as never and much safer in the air!
