ZAxis
For those with the Sony Nex 5, how do you go about snapping photos? There does not seem to be a remote port. I see some using an IR remote signal. Only other way is a mechanical arm that pushes the shutter release.
As Droider we use a Gentled shutter release
Its basically an infra red LED with control chip on the end of a standard servo lead. Just plug it into a spare servo port on the FC and setup a transmitter switch channel to trigger it. Mount the LED somewhere that the sensor on the front of the NEX will always see. Our's is on a bracket added to the side of the camera cradle so it moves with the tilt of the cradle.There is a small delay before the shutter is released but that can be lived with.
www.gentles.ltd.uk/gentled
