MombasaFlash
Heli's & Tele's bloke
I am well into my camera comparison ordeal and have currently reached camera number eight, the Panasonic GH2.
The first thing is, WOW! Talk about sharp video images. Litterally everything else I have tried pales in comparison.
But ... there is always a BUT.
It has two video outputs (WOW again !!!), composite (or AV) and HDMI but for the life of me I cannt work out how to get live video preview out of it for monitoring. The manual explains that the AV out only works for playback of recorded images - OK ... stupid, but OK - and then it says that the HDMI output, which is for viewing recorded images on your HDMI equipped TV, also outputs video when recording.
Well I really would like to know how, precisely?
With the HDMI convereter set up and the downlink monitor on etc. plugging the mini-HDMI cable into the Sony NEX produces an image. Take out the cable and plug into the GH2 and ... nothing.
Without live preview, all the image sharpness in the world is rendered useless if you can't frame accurately. Yes, yes I know, use a separate FPV camera. No I won't. I don't like it. I want the camera's live output so that I can really see the framing and also know when it has turned itself off or is doing something weird. I thought that Sony were taking liberties when I discovered it only has an HDMI output and no AV out. That was overcome with the awkward HDMI converter. But not having ANY live video out at all is plain bloody ridiculous.
Surely it must have. Can one of you GH2 afficianados please shed some light?
UPDATE:
The next logical step was to connect the GH2 to a pukka HDMI equipped TV/monitor. If ... IF ... you connect and switch on in a very precise order the live video comes up on the HDMI equipped TV or monitor.
Mind you, if you connect the Canon 5D or the Sony NEX to those same TV and monitor the picture comes up regardless of what is switched on or connected first.
So it seems the HDMI converter and the GH2 are somehow incompatible. GREAT! God. Why do these companies do this sort of thing? They produce such great kit and shove it all in the toilet for a small pissy reason.
EDIT #2:
No, it is the GH2 because I had forgotten that playback video is output from both HDMI and AV outs. Feed the playback via HDMI through our clumsy old HDMI converter boards and it pops up without a problem.
Does anyone know if this issue is addressed in any of these famous 'GH2 hacks'?
UPDATE:
EDIT #2:
