what are you flying these days Jes? Last I heard you had something on the drawing board.
The Boca site had a promotion at the end of last year, 50% your whole order so I stocked up. If I have some time later I'll test your theory that they should be less money elsewhere but your Abec1 is the same price as the Abec5 I quoted. The difference is mine is shielded, yours is sealed. The only place I'm seeing a sealed bearing as possibly required is the top position on an inverted motor, everywhere else they're holding up fine.
Regarding your comment about our speed rating, by what I've been able to tell, ours is actually a low speed application for these bearings which should make the grease a lifetime lube. Out-of-round bearing races may make things heat up a lot more and make the grease melt out but lubrication shouldn't be necessary if everything else is normal.
Good discussion.
Bart
I've built two "mules" for testing out various frame and gimbal ideas, but so far I'm only flying for that purpose.
Boca, of course, are a niche supplier - they charge a hefty premium for bringing standard industrial components together in one place and describing/supporting them for specific "amateur" applications. They trade heavily on the "cool factor" of ceramics, orange rubber seals and using descriptions like "Grease Power Lightning Lube" to sell standard lithium grease at an inflated price
Actually I haven't used sealed bearings yet - I, too, bought in bulk (before I'd thought of using sealed) so I have about 100 bearings left to get through, at which time I will switch to sealed units. Incidentally, one of the other advantages of rubber-sealed bearings is that you can very easily remove/refit the shields to wash out the interior, inspect and re-grease - that in itself may make them a better bet.
Regarding the speed rating - yes, in pure rotational speed terms, this is a low-speed application. But, as I said in one of my long posts, the heat, vibration and operating environment to which we subject these bearing strongly suggests "de-rating" them, i.e. treating them as if they are in a "high speed, harsh environment" application.
That's a difficult question - the only way to establish the answer mechanically is to record and graph failures in use and then apply a safety factor, i.e. wait till you've crashed enough times due to bearing failure to establish the pattern. In practise that would be a long and expensive exerciseJes is there a rule of thumb for how long till we should replace bearings?. I finally have a machine I am happy with and it's doing a decent number of flights so I'm wondering about the frequency of maintenance of bearings etc.
So if I have a "good quality" hard disk I don't need to make backups of my important data?If you have good quality bearings and off course no crashed you wont change them..
