Flydigital
..Not sure if that's the correct term for what I'm experiencing.
I charge a 3s battery to 12.6v. Once it's off the ground the levels are immediately into the 11.x range. I have a 1st warning beep set on my Tx of 10.6v and 2nd set at 10.4v.
Within a couple of minutes I start getting beeps when I go full throttle up. So it may be at 11.2v at hover then drop down to 10.2 on a major thrust then recover back above 11v.
Is this a sign of poor quality batteries? They have been used about 20times max, each battery.
(Turnigy Flight Max 3s 500maH on a F550) - correction 5000mAh
Thanks for any help here..
