Battery for S800 question
olof
Osprey
You can run them is series thus getting the increased voltage. Parallel will give you the initial voltage, just more amps.
I run 6s lipos in parallel for added redundancy, if one pack loses a cel you still have full power. When in series the likelihood of a bad cel doubles (statistically that is).
I use dual 5500 or 6000, that seems to be the sweet spot for S800/Zen combo.
Benjamin Kenobi
Easy? You call that easy?
Agreed. I wouldn't recommend using two 3S in series. Your flight time would be short. I also use two 6S 5000mah in parallel and get a good 10mins flight fully loaded.
