Yes Hitec X4 will do the job, i have one, it's a beast of a chargerSo you are saying that a Hitec X4 would do the job?
if your sweet talk game is stellar, then go for the gusto and get the Dynamite Prophet Sport Quad 4 X 100W, that's my next purchase, they have two versions 1 is: 4 x 50W 2 is: 4 x 100WThanks for the info. Now to sweet talk the wife lol
no I was talking about my Hitec x4 which is 80w per ch...so your telling me if I choose 6.0 amps it won't charge...mine is not a built in A/C I have to provide a separate power supply which I'm using a 400w power supply...each ch is it's own separate chargerIf your talking about the 100 watt channel charger you mentioned above, isn't going to be able to give you 6 amps at 6s. That's 130 watts at 3.7 volts per cell and it only gets worse as voltage increases.
You could parallel charge on a higher watt per channel when you wanted to charge multiples and also charge a single battery faster if you wanted.
ok thanks good 2 knowWatts is Volts x Amps
It may be charging when you tell it to go at 6 amps but it cannot be putting 6 amps in that voltage. On the other hand my TP610 AC will just error out if the voltage and amps exceeds the limit, about 80 watts.
If your dealing with 80 watts you have two points to consider: 3.7 volts per cell and 4.2 volts per cell.
80 watts / 22.2 volts = 3.6 amps at 3.7 volts per cell
80 watts / 25.2 volts = 3.2 amps as you near 4.2 volts per cell
6 amps x 25.2 volts requires about 150 watts as you approach 4.2 volts per cell.
