Hi all I have a yun-1 for my f550 and I'm considering selling it for the CM2000 because I don't like the way I have to use a zip tie to mount my camera on the yun-1 and because of the size of the base plate its requires re-calibration every time I need to take it off to charge or battery pull the gopro etc. I have ordered a right angle USB adapter to be able to charge and copy footage off of it whilst still mounted but I don't think its an ideal solution.
I'm considering the Arris CM2000 (I'll be using gopro 3 black) but wondered if when you mount the camera on the seemingly much smaller base plate, does it always mount in exactly the same position and if so do you then move the plate somehow for balancing, or like the yun-1 is it a case of sliding the camera around on the base plate to get the balance right? I think I'm right in saying there is some sort of velcro strap included with the CM2000 too, is that right?
I currently use the AUX3 knob on my Spektrum DX8 to control tilt, I take it I'll be able to do the same thing on the CM2000?
I suppose my final question would be has anybody already made the switch from the Yun-1 to the CM2000 and if so what did you think?
