Anyone S800 with Naza gain setting?
Zzr
Hi,
Anyone use Naza for S-800 ? What's your setting basic parameters without gimbal?
thanks for advance!
Zzr
Hi Ferdlinand Thanks for parameters #. The fireworks are so awesome! I'm planning to order for DJI gimbal gopro when will be release out.
180 180 130 150 80 80
best regards
Ferdinand
Zzr
What's your idle speed motors? 1/2 is only 4 motors spooling but 2 motors are not spooling. I moved 3/4 and whole of 6 motors are spooling.
Idle speed motor bar.
recommend is 1/2
3/4
high is full
FerdinandK
I did not touch the idle speed setting, so they are at whatever is the default value. If some motors are not spinning you can correct this by giving a yaw correction before liftoff.
best regards
Ferdinand
Zzr
Thanks for reply. Are you using S800 original? mine s-800 clone cuz different ESC by SimonK
best regards
Ferdinand
jcampen
How did those parameters go for you? The only one I am not sure on is the attitude gains. I see on other forums they are setting these at anywhere from 100 100 up to 200 200. I am sure 200 is way to much, but quite a lot are using around 150 150 for attitude gains. So this one 80 80 seem a little low? What you think?
